  • 1 Reply
  • 1451 Views
Uclaby7
I set my arlo lights color and %. I walk away and, when light triggers, goes to max output no color (standard output). It will not remember settings. How do I get the lights to remember settings?
Sarath_Inampudi
Arlo Employee
Arlo Employee
It sounds like you are changing the Manual settings only which defines the Light's characteristics when using the toggle switch. Note that the Light has separate Manual and Automation settings. For motion trigger customization, you should edit the Mode rules for the desired Light in order to see the behavior you want (color, flashing, etc.).
Please check out these posts for further information on this:
  • 1 Reply
  • 1452 Views
