Changed WiFi, trying to connect Bridge. Takes 3 minutes to reboot but says offline.
  • 2278 Views
zubidubi
Changed WiFi, so trying to connect bridge. Bridge connects and it says will takev3 minutes to reboot, but the bridge goes lightless and app is showing offline
Sarath_Inampudi
Arlo Employee
Arlo Employee
The App will show the Bridge as offline during those 3 minutes (since you already saw the WiFi change successful message and were asked to wait). Did you try checking in after to see if the Bridge is now online again? Note that during regular operation, the Bridge LED remains off.
zubidubi
No luck, it doesn't come back
JessicaP
Hey zubidubi,
If you're still having problems, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 2279 Views
