Arlo Security Light LED Light Always On
  • 8 Replies
  • 6205 Views
Arelo
I just bought a brand new Arlo security light. I noticed the 4 LED's are always dimly on even though light is turned off and I set it so it does nothing when motion is detected. The only way I can turn off this weird dimly lit problem is take out the battery. Is my light defective?Always LitAlways Lit
I recently had a similar problem. If reinserting the battery doesn't help, remove the light and resync it.
8 REPLIES 8
ShayneS
Hi @Arelo
If you are still experiencing this, please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
surfer1000
Luminary
Luminary
I've got the same problem happened while charging up from mains removed it as its 100% light is on dim won't go off!
surfer1000
Luminary
Luminary
My four lit bulbs are different to yours.
surfer1000
Luminary
Luminary
Arelo
Remove the light from the app and go through the entire setup again solved the problem.
surfer1000
Luminary
Luminary
That doesn't stop it, when I remove it, it goes bright for a second then back to the four dim lit bulbs on!
Arelo
Open your Arlo app and remove the light. Take out the battery for at least 5 minutes. Put battery back in and follow the instruction manual to setup light again.
  • 8 Replies
  • 6206 Views
