  • 20 Replies
  • 7208 Views
tripmaster
It looks like there is no option to have the motion sensor/light on the Security Light (I know, it's EOL) trigger the Arlo Pro 2 in the app.
Seems ridiculous to me as I get notifications, so I thought I'd post here if someone has figured a way around that?
@tripmaster wrote:
I dont have those same options - using the Arlo Spotlight... I cant see the images on my prior post.
Maybe try deleting the rule for the light, and then add it back.
No need to post the rule for the camera, this has to be set up in the rule for the light.
20 REPLIES 20
michaelkenward
Sensei Sensei
Sensei
Not sure what you mean by "Security Light". If you mean the old lights that use the "Light bridge", then you can get that to trigger the Pro 2.
Start with a Mode for the Light bridge.
  • If Motion on Shed light
  • Add Device
  • Pro 2
Proceed as usual.
Does that get what you want?
Just another user
tripmaster
I dont see my Bridge on my Devices list (I have one) - just my light?
I see it in my devices list, just not in my Routines UI...
michaelkenward
Sensei Sensei
Sensei
Have you tried adding the Bridge to the set of Arlo devices?
It has a habit of going AWOL here.
Just another user
Do you see it as an option when you add a device rule?
michaelkenward
Sensei Sensei
Sensei
And what do you see for the light in My Devices?
Just another user
tripmaster
Here's what I see!
tripmaster
tripmaster
I see the Bridge in my devices list though?
tripmaster
No ability to use it as a trigger, or be a trigger for another device's rule.
When I go into the rules for a mode, I can add a rule for the light.  That rule lets me add "record a video" as an action (specifying what camera I want to make that recording on).
It'd be useful to know how far you can go down that path.
  1. If the light is not in your rule list, are you seeing the light as an option when you add a rule to your existing modes?
  2. When you edit that rule, are you able to add an action to record a video?
tripmaster
So this is my backyard camera. I added a rule that when it records, record a video on my front yard camera too.
There's a list of devices I can trigger with a camera activation.
The light's entry in that UI shows no ability to add any rule?1-backyardrule.jpg2-lightrule.jpg3-devicestotrigger.jpg
So you have the Arlo Spotlight listed as a rule in Arm Away.
When I go into that rule, I see
When I then "add an Action", I see
I check "record a video" (as shown), and then press "next" in the upper right.  That gives me a list of cameras, so I can chose which one records.
michaelkenward
Sensei Sensei
Sensei
Taking that one stage further, this is the screen I get to:
I also have the light set to trigger other cameras and a floodlight.
Just another user
tripmaster
I dont have those same options - using the Arlo Spotlight... I cant see the images on my prior post. Screenshot 2025-05-27 112940.jpgScreenshot 2025-05-27 112923.jpgScreenshot 2025-05-27 112900.png
michaelkenward
Sensei Sensei
Sensei
Yes.
Go back to the first message.
@tripmaster asked:
"option to have the motion sensor/light on the Security Light (I know, it's EOL) trigger the Arlo Pro 2"
That's the clue. The Security Light triggers the Arlo Pro 2.
Just another user
tripmaster
Deleting the rule deleted the device from the routine...
Of course.  Now add it back by pressing ""Add Device Rules" at the bottom of the rule list.
tripmaster
I removed the Bridge and re-added it - and connected the light. NOW i have the option to add rules. Turns out removing and re-adding was the solve. Thank you all.
michaelkenward
Sensei Sensei
Sensei
Good move.
I find that the Bridge has a habit of going missing when the network has the slightest hiccup.
Uh oh. Just noticed that mine is flashing again. Been playing around with routers.
I keep an image file of the QR code for the bridge so that I can point at that rather the the fiddly little on on the plug itself.
Just another user
  • 20 Replies
  • 7209 Views
