  • 3329 Views
BoltKC
Is the Arlo Essential compatible with a 5.0 Ghz wifi?
JessicaP
Hi BoltKC,
Just to be sure, are you referring to the Arlo Security Light or the Arlo Essential Spotlight camera?
BoltKC
I was referring to the Essential spotlight camera but I would be interested about the same question for light itself as well...
JessicaP
The Arlo Essential Camera can only be paired with a your router's 2.4 GHz WiFi band or a Base Station/SmartHub.
The Arlo Security Light is paired with your Arlo Security Bridge, which can be paired with your router's 2.4 GHz WiFi band.
  • 3329 Views
