  • 2870 Views
nmjones
I have two motion detectors for my ABB1000 bridge. When they activate, I get two seperate times displayed. The first time displayed shows the correct time. The second time displayed shows incorrect time (one hour ahead). I have included an attachment to help with what I'm trying to describe. I am in Arizona and have Arizona time zone selected. I also have 8 cameras (5 Arlo Pro 2 cameras and 3 Ultra 2 cameras. None or these have that issue. Any suggestions.
Have you tried removing and readding the device to see if that helps?
nmjones
Not yet. About two months ago I installed my new Ultra Pro 2 cameras. To get the motion detectors to work again, I had issues and had to do factory resets. Back at that time, I ended up doing about 3 factory resets. I figured I would do it again, but first, I wanted to see if anyone knew for sure what was going on. I'm not sure when this issue started. Just noticed it a few days ago.
nmjones
OK. Factory reset resolved issue. Guess I was being lazy. Didn't want to get on a ladder, remove my motion detectors and rescan bar codes.
  • 2871 Views
