I talked to support and it seems for the Arlo Subscription in order to backup videos to the cloud for more than 1 camera you have to buy the multi camera plan. So 1 camera will cost you $2.99 but if you want 2 cameras you have to pay $9.99 for the multi account plan. So each camera will then cost you $5 to backup to the could. That is just stupid. Would not recommend these cameras. I also get an annoying buzzing that no one seems to be able to fix with the recordings. Not happy with these cameras or the support for them.
Hey @Wasabijim
You can add two single camera plans instead of the standard Secure plan.
is this buzzing coming from both cameras? May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
