Widgets galore
  • 6 Replies
  • 2153 Views
Edinburgh_lad1
Every time I clear cache, clear data and re-install the app, I end up having lots (I mean like triple or quadruple of what I already have) of tiles on dashboard. I've done it twice now and each time this happens.
ShayneS
Would you be willing to send over a diagnostic log right after replicating?  I can provide instructions if you need it .
6 REPLIES 6
ShayneS
@Edinburgh_lad1 This is with Android correct? or do you have an iOS device experiencing as well?
ShayneS
@Edinburgh_lad1
I wasn't able to replicate this with the latest version of Android 6.26.1. I followed your directions >  deleted data/cache uninstalled > reinstalled and I had the same amount of devices listed in the dashboard. Is there any way you can screen record the process and send via email with a log attached?
ShayneS
Does this occur with 6.27?
Edinburgh_lad1
Yes.
ShayneS
Edinburgh_lad1
Hi
I've tried with the app version 6.27.0+6270005 and this version solves the issue. Thanks.
