Every time I clear cache, clear data and re-install the app, I end up having lots (I mean like triple or quadruple of what I already have) of tiles on dashboard. I've done it twice now and each time this happens.
Would you be willing to send over a diagnostic log right after replicating? I can provide instructions if you need it .
@Edinburgh_lad1 This is with Android correct? or do you have an iOS device experiencing as well?
I wasn't able to replicate this with the latest version of Android 6.26.1. I followed your directions > deleted data/cache uninstalled > reinstalled and I had the same amount of devices listed in the dashboard. Is there any way you can screen record the process and send via email with a log attached?
Does this occur with 6.27?
Yes.
Hi
I've tried with the app version 6.27.0+6270005 and this version solves the issue. Thanks.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
