  • 17 Replies
  • 3273 Views
  • 5 In Conversation
alex_loo
Virtuoso
Virtuoso
Got this latest Android version 5.2.2_28766.  First change I notice is duplicating local storage to a separate tab under FEED, which is making better sense.
Do we know if it fixes any issue?  Say geofencing?
Best answers
  • ShayneS
    Thank you for the info, I already informed the team. We will report back as soon as possible.
17 REPLIES 17
Edinburgh_lad1
Hero
Hero
It creates more issues. Honestly, this company can't ever get  things right, can it? On Android. Upon starting the app - no access to local storage at first.
@BrookeN
alex_loo
Virtuoso
Virtuoso
yes, I was just saying this too early.
Now, even Devices >> Base > Storage Settings fails.
And then this new  Feed >> Local fails as well.
In a nutshell: the new app has not enhanced the user experience, but instead introduced additional bug, STOPPING service that used to be at least working.
FWIW, I didn't lose access to local storage when I got this app (I am using the iOS version).
alex_loo
Virtuoso
Virtuoso
so are you now able to access local storage from both of:
  • Device >> hub >> Storage Settings
  • Feed >> Cloud
Edinburgh_lad1
Hero
Hero
On Apple it's ok. On Android, it's not working as it should. Also, it displays yesterday's recordings and there is no possibility to change that.
@BrookeN can you tell us please why Arlo is *yet again* releasing a version/product that hasn't been tested? I've spent too much money on this system to just simply get rid of it, and I strongly object to being used as a tester and to be given these half baked versions! Would you please send this feedback to Arlo's development team and whoever, if anyone, is in charge of it?
alex_loo
Virtuoso
Virtuoso
hehe, I am feeling @StephenB may have more insider information 😉
alex_loo
Virtuoso
Virtuoso
On Apple it's ok.
 yes, checked with my wife's iPhone too.
Simply agile development without testing, and becoming FRagile.
  • Feed >> Cloud
Well,
  • Feed >> Local
Again, that is with the iOS app.  Apparently there is a problem with Android.
No, I have no info about Arlo development and test processes.
Like everyone here, I am troubled by the ongoing quality issues and the obvious gaps in the "Feed" interface.
I have only Android and like @StephenB I have access to local videos with both hub storage settings as well as in Feed. I just tried it again with no issues. That doesn't mean there may not be problems but my first suggestion would be to either reboot the phone or at least force stop the app and try again.
ShayneS
Edinburgh_lad1
Hero
Hero
@jguerdat
1st issue:
Remove the app from memory. Wait a few minutes. Open the app. Go directly to Feed. Select 'Local'. What do you see? (Mine shows 'no videos for today' or something to that effect, then after a few seconds all videos load.)
I have Android 14. Moto Edge.
2nd issue:
Remove the app from memory. Open the app. Go to 'Add a device' in the top right corner. Cancel adding a device. Are your tiles black?
alex_loo
Virtuoso
Virtuoso
looks like this has been resolved.  From my android here, I can see local storage both from Feed >> Local and Devices >> hub >> storage settings.
Thanks.
@jguerdat
1st issue:
I don't see that here on my Pixel 6 with Android 15. I do see a lengthy circling circle while loading from the hub which seems like that would be the same thing. I do currently have ~22GB of storage used on my SD card so that may explain the length of pause before display.
2nd issue:
Only for about the same time as it takes for when first opening the app. The thumbnails load quickly after maybe 2-3 seconds (didn't actually time it).
alex_loo
Virtuoso
Virtuoso
Devices >> hub >> storage setting is at least back to its previous "normal", I can see and playback local recording.
However, the "new" changes are still buggy (for me as a non-subscriber)
  • click FEED, it does NOT show "cloud" and "local" tab.  This is incorrect
  • view local recordings from "devices" side, and go back to FEED, then "cloud" and "local" are there.  sounds good?
  • BUT! if you click "local" tab, the content is incorrectly empty
  • refresh this empty "local", then it finally shows local recordings correctly
Alex
Edinburgh_lad1
Hero
Hero
I want my old green Arlo app back as this thing is not fit for purpose. It's work in progress and not even beta but some kind of pre-alpha project by a high school kid.
The new Feed feature is showing the same date for every event and you can't even change it to display the latest recordings.
Why is this even permitted to be released?
2nd issue:
Circling back on this. Tried this again yesterday without removing the app from memory and got black tiles. Did this multiple times to be sure. Switching to a different screen (Feed in my case) and then back had the thumbnails already loaded.
