A few weeks ago, my video clips from Arlo Secure cloud stopped playing on my Android mobile app. This issue applies to my two cameras and doorbell, so it's not specific to a particular device. I get a buffering message and it just spins endlessly. The web app works fine, just the mobile app has this issue. I tried uninstall/reinstall with no improvement. This video clip playback issue has been a problem in the past, and I don't see any indication that Arlo ever fixed this properly. Am I alone with this problem, or do others experience this too? And how can it be fixed?
Swapped out my old xfinity modem for a new one and problem solved! Old modem must have had a weaker wifi signal that prevented clips from playing. Now it seems fine.
Which version of the mobile app are you using?
Maybe you have a security setting on the phone that impedes WiFi access? I have a couple of security packages installed on mine that can be set to limit WiFi access.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
