VMB4540 or VMB5000 Smart Hub which to buy
I have 1 Pro 2 and 4 Pro 4 cameras, now connected to VMB4000. I would like to upgrade to either the VMB4540 or VMB500 as I would like to be able to access any motion a camera picks up on my iPhone while traveling. I think I understand I need a new smart hub. and I should be able yo do port forwarding I believe with the VMB4540 without a great deal of hassle. To be honest I have tried to read everything I can but am confused as to which unite to buy and would be easiest to work. I think I just read there is a iOS issue using port forwarding. Any help or suggestions I would be most grateful.
Margrave
@Margrave wrote:
I have 1 Pro 2 and 4 Pro 4 cameras, now connected to VMB4000. I would like to upgrade to either the VMB4540 or VMB5000 To be honest I have tried to read everything I can but am confused as to which unite to buy and would be easiest to work.
The VMB4540
- supports usb storage
- creates a 2.4 ghz wifi network for the cameras
The VMB5000
- supports microSD storage
- creates a 2.4 ghz and 5 ghz wifi network for the cameras
Your Pro 2 and Pro 4 cameras are 2.4 ghz only, so they cannot take advantage of the 5 ghz wifi in the VMB5000. So the only spec difference that matters to you right now is whether you want to pay extra to get a microSD slot instead of a USB connector.
Note that 5 ghz wifi has less range than 2.4 ghz, so even if you had a dual-band camera (like the Ultra or Pro 5s), you would still likely be using 2.4 ghz for your outdoor cameras.
Correct. That was first reported here about 6 weeks ago. Arlo has not said when they will fix it.
A home VPN is another option, although it can be more difficult to set up. My Netgear Orbi router has OpenVPN built in, and that is what I use instead of port forwarding. (BTW, I use an iPhone, so the home vpn approach is not affected by the port forwarding bug).
Either way, remote access isn't possible with some internet service providers. T-mobile broadband internet is one, as they do not support inbound connections to your router - so home vpn and port forwarding can't be used with their broadband router. I think other US mobile broadband services have the same issue. Some landline providers are now using a technology called CGNAT which also doesn't support inbound connections. So you might want to check if port forwarding works with your current ISP. You can forward a port to a PC (say 54321), and then use a port check tool like https://canyouseeme.org/ to confirm that the port is open.
If you are wanting to drop your subscription, then there are some limitations to local storage that you should be aware of:
- recordings are only available in the app - not my.arlo.com
- recordings are only available from the primary account - not friend accounts
- there are no thumbnails, so recordings need to be downloaded to your phone to view anything
- you cannot make manual recordings or take snapshots.
Of course you'd still get cloud recordings from your Pro 2 (in addition to local recordings). There is no free cloud recording for the Pro 4 (or any currently sold Arlo camera), so if you drop the subscription you'd only be able to use local recordings for those cameras.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
