I have just upgraded to the new app. I have 9 devices in 2 different locations and understand to separate out the locations and have different schedules, I need to purchase a 2nd subscription. Unless there is another way to get around this that someone can suggest?
If I do purchase a 2nd subscription, can all the devices be shown on 1 Dashboard instead of having to log in and out of different accounts, ie 2 different dashboards (iPhone)? Thanks
The different locations can't be worked around as with the old UI. However, to see the cameras at another location, just click on Home to choose the other site. You may want to rename them to help keep them straight. No need to log out and back in using different credentials.
Thank you for the advice. I have set up a 2nd subscription and am able to access both locations as you mentioned. Appreciate the quick response.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
