Unable to view local recordings
After the update and the forced trial upgrade now ended, I am unable to view my local recordings. In the "Feed" tab > "Local" my base station says "No Events".
Walked through technical support to verify all the settings were correct ("View Recordings" toggled on, all devices on same network etc), factory reset all devices, and attempted to access via a different mobile device.
Afterwards, they escalated the ticket on their support side I was told that my hub was defective and that they would offer to replace it at a discount. I'm skeptical, I was able to view the local recordings a couple weeks ago.
They told me they are 100% sure this is a hardware issue and not a software issue, but it seems like other non-subscription members are being affected in a similar way.
Anyone else in the same boat?
Hardware: vmb4540 (smart hub base station) and pro 3 cameras
Best answers
No I have not un/reinstalled the app.
But I got a pleasant surprise today. Today it actually works…
Yesterday videos have appeared and new videos do appear directly after they have been recorded (refresh needed in history)
Maybe someone responsible for Arlo’s backend have done a restart or other correction?.. 🙂
Hi @cinemafaux
Have you verified these devices are set to record in the rules? If you put the USB Drive or micro sd card in a computer do you see any recordings? Is it possible to test with another usb or micro sd card And verify all rules are set to record with your cameras and modes and test again. You can find more detailed Info on setting up local storage here.
A reddit user reporting the same issue suggested this fix and it worked for me.
"in iOS setting for the Arlo App (not in the app itself) there is a slider switch for “Local Network”. After I enabled that, I was finally able to view local recordings."
Nothing new. It’s been like this for over a year now, if you don’t pay, you’re entitled to nothing — except having paid a lot of money for very expensive equipment that’s no longer of much use. Fortunately, others are there.
Thanks for the feedback. Without a service plan, your Arlo device will continue to have the following features:
- Live Streaming
- Push Notifications
- Two-way Audio
- Auto Zoom & Tracking*
- Local Storage Recording*
*Auto Zoom & Tracking and Local Storage Recording are not available for all Arlo devices.
Note: Without an Arlo plan or trial you will not have access to features such as Video History and Activity Zones. You can find this info here
If can provide more detail regarding any symptoms your experiencing I will do my best to assist you.
VMB5000r5 here and since the last software update and subscription offer ending I too no longer can see any local videos except for ones that predate July of last year. Anything more recent, including from notices of activity, do not show up. Storage is fine and the old videos I can see are fine.
what’s going on?
Try uninstalling and reinstalling the app.
Same here…
With the difference that I just bought the VMB5000 (to have videos stored locally for control/privacy reasons and not need a subscription) and upgraded to the new app before including the camera to the hub. So I have not experienced a working local storage with the old version of the app.
But the results are the same.
- Events not recorded.
- No videos visible
neither under ”local” nor ”cloud”.
This does not align with Arlo’s promises for the ”smart” hub, and I find nothing of relevance on their support pages.
I just hope this is a SW bug that they will fix soon or I’ll have to follow the advice to jump the ship (as other smart home users recommend since Arlo no longer support inclusion in e.g. Homey)
- No videos visible
Did you try uninstalling and reinstalling the app?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
