I recently purchased and installed the video doorbell on a rough stucco wall using the provided screws, terminal wires with wire nuts and angle bracket. The doorbell body refuses to latch the bottom clip to the mounting plate. I've tried various wire arrangements and screw tightness to try to solve this. There is a recess behind the mounting plate that holds the wires and wire nuts. When I unmount the base plate it will clip on to the body. Any thoughts or work arounds?
Is it possible that tightening the screws along with the rough surface is causing the base plate to flex to the point the doorbell won't click into place? I'd suggest putting an appropriately sized piece of thin wood on the house surface and then screw the base plate onto that.
@TMSISOLAK: FWIW, I've found that loosening the screws a bit can fix this issue.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
