I bought Arlo essential Camera and activated it on my account, but my 3 months Trial didn’t activate as well. How can I activate it?
Are you in a country where Arlo offeres subscriptions? There is a list here: https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
If answer is no, which Camera support that without having a subscription?
@Nikola89 wrote:
I am from Bosnia & Herzegovina. Is there any other way that i can see recordings from essential Camera connected to base station VMB4000?
You could upgrade the base station to a smarthub (VMB4540 or VMB5000), and then use direct access to local storage. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are several limitations you need to be aware of:
- direct access is only via the app (not the web browser)
- direct access is not available to friend accounts
- manual recordings are not possible
- there are no thumbnails
- it can be tricky to get direct access working when you are away from home (either port forwarding or a VPN is needed).
As far as alternative cameras go, the Pro 2 model is the most recent one that supports cloud recording w/o a subscription. Essential, Ultra, and Pro 3/Pro4 models do not.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
