Sunset/Sunrise mode for only 1 camera?
I have 5 Pro 5s cameras and a Smart Hub. I want to create a sunset to sunrise activation schedule for just one of the five cameras. Any suggestions?
You can use any of the 3 default modes to do this but that uses up one for just that purpose. If that works for you, edit that mode and have a rule for only that camera in it. Then set up the automation for sunset with the action being to change the mode you just edited. That will set the mode to be active but you will also need to add another automation for sunrise to change the mode to something else. You can't set a time period (sunset to sunrise) in one automation so create two.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
