Since new version of app went out my system doesn’t fully work.
I can access the app and it tells me my cameras are offline, after a moment or two of searching. I have called the power company they say power is making it to the location. My live view isn’t working, past clips are still playable. Here is the kicker, I get random notifications of motion detected and a video was made, but it never shows up on the log of videos, just the old ones before the update. Nothing has changed at the location, and I didn’t do any app upgrades.( I assume they are made automatically). The app just asks me to upgrade to the new system. I assume the new upgrade comes with a subscription. I have kept my system, off of a subscription service and would like to keep it so. I bought and set it up where I monitor and store images on my own network.
I can not reset the system at the location from here, and am afraid if I do the system will no longer be operational without having to buy a new system.
How do I get my system back to the way it was before. I assume there is a work around to give existing clients back what they paid for?
No it does not. And if you have the free 7-day cloud storage (offered with legacy cameras) you still have that. That would continue even if Arlo migrates you to "Feed".
I am tagging @JamesC , @ShayneS , @BrookeN , as they can do a back-end sync of your system which might resolve the recoding issue.
Same problem, with cameras randomly showing as offline. Yesterday three of five were supposedly offline for a while, and today it's four of five at the moment. Shoddy stuff.
UPDATE: I thought I'd try restarting the hub, which made no difference, so I then tried to add a new camera. The hub didn't find any but three of the four that were offline came back to life. I repeated the exercise, which again found no new cameras, but now all five are back online.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
