Select all to delete option missing
  • 2 Replies
  • 1994 Views
JanaeLovae
Arlo Pro 2 Model no. VCS3000C
I had a 'Select All' feature to delete multiple videos from the same day and now that option has disappeared.
Was this feature taken away or do I need to re-install the app to get it back? Deleting one video at a time is too time consuming. I've seen other comments about this on this forum but I don't know if the problem has been fixed.
Please advise. Thanks
DannyBearAgain
Arlo is running two User interfaces embedded in the arlo app. The original UI has a library page which is likely what you had and the new UI has a feed page which is likely what you’re missing.
Arlo will not allow you to revert back to the original UI even if you create a new account so you have to suck it unfortunately.
https://kb.arlo.com/000062798/How-do-I-upgrade-my-Arlo-Secure-App-4-0-to-the-new-experience
ShayneS
Hi @JanaeLovae
Are you still experiencing this issue?
