  • 6 Replies
  • 1568 Views
Draik89
Salve a tutti,
Ho 2 quesiti
1 Appena comprata 3 mesi fa la telecamera sono riuscito a cambiare la suoneria di notifica e adesso neanche riesco più !!
Mi date procedura passo passo per android??
2 Avevo abbonamento da 4.99 euro per singola telecamera e ora nonostante sia rinnovato per un mese mi hanno tolto i feed le registrazioni!!
Mi potete aiutare
Grazie 😉
6 REPLIES 6
ShayneS
Can you check for the Settings > Apps > Arlo Secure > Notifications > Notification categories> Notifications> Sound >  Notification categories section
Draik89
Yes i know this.... But i see only active notifications and disactive notifications
ShayneS
Do you have any other options like this?: ""On your phone settings, Can you try navigating to Settings > Apps > Arlo Secure > Notifications > Select Notifications > Sound > Change sound > Save.""
Draik89
     Only this.... It's impossibile to change
Draik89
Make a screen on your app please
ShayneS
I have escalated this to the appropriate team and support will be reaching out to you as soon as possible.
