Pro 4 Disconnecing
Hi
Since upgrading to UX4 to resolve a geo-fencing issue, I’m finding one of my cameras, a Pro 4 is losing connection to the base on a weekly basis. This was not a problem before upgrading. I’ve checked all firmware, removed and re-added, moved close to the wifi and tried with power. None of which make a difference. The only way to fix is by pulling the battery, however, this only lasts about a week before another disconnection. I also have 3 pro 2’s, which work fine.
You've done what I would suggest so use the app to go to Settings, Support and select your camera. Scroll down to Contacts to see what official support may offer.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
