To rub salt to the wound, when one specifies routines and actions, there's an issue with playing a sound. If you want to play a dog's bark or any other sounds on two chimes, the app crashes.
The Dev Team should be ashamed of releasing this keech (= Scottish word for sh**).
Can you provide the steps to replicate this symptom as well as the app versions you are running?
Thanks,
I provided all the info to my team and they are reviewing.
Symptom could not be replicated. Which version of the app are you using now?there have been a few updates. I don't see any chimes attached to this email, which model chimes are you using?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
