  • 13 Replies
  • 1415 Views
Donatello57
Every day, I am having to log out of the app and then log back in in order to see activity from the night before. It shows there was activity, but no video saved. Anyone else having this problem?
Olega
it works now! Hopefully next update won’t break something else 🙂 Thanks
13 REPLIES 13
BrookeN
Are you still seeing this same behavior?
Donatello57
There was no activity last night but this has been an ongoing problem. I can let you know tomorrow morning.
BrookeN
Just checking in to see if you are still seeing the same behavior with the  feed?
Olega
Same issue for me I am on the latest iOS. iPhone and iPad.
BrookeN
Have you uninstalled and reinstalled the app? Is this with all cameras or a certain one?
Olega
Yes. Uninstalling and reinstalling was first thing I tried.
BrookeN
Is it all your cameras that don't show up or is it specific ones?
Olega
Local recordings stopped showing in feed since latest update. The only way to see them is when you go to my devices select base go into the settings then you can see it. However, older recordings prior to latest update is visible in my local feed. Tabs in my feed cloud and local not usable anymore. There are too high UI is messed up
BrookeN
Can you please send a screenshot of what you are seeing.
Olega
Not able right now.  Have your engineers Grab iOS device and update to their “latest and greatest” and see it. Upper tabs in my feed for cloud and local is broken and unusable. Every other update breaks something.. last issue took them several month to fix. Hopefully this is not the case.
BrookeN
We are already investigating the feed/local I will update the community soon.
BrookeN
Olega
