No Local Storage Recordings
I have the VM4540. I’ve been able to view local recordings until this week. The apps feed prevents me from viewing any recordings without a subscription. What changed?
I noticed the same thing. The options under the Feed have disappeared. I had to go into the Hub as a device and go under Storage Settings.
This is inconsistent in terms of view-ability until the memory is removed and uploaded to another device. I can the there are recordings actively being saved on the feed screen, but not showing up in the storage settings page. This has been happening since I got the device and stopped using cloud services. Any idea how to remedy this?
At this point I’m so upset with this dysfunctional product that I’m considering moving to Eufy and speaking to a lawyer about false advertising for these Arlo products.
Can you provide some details on what camera models you have (and how many).
I'm having the exact same problem since about a couple of days ago.
My Arlo SmartHub (model VMB4540r2, firmware 1.31.0.0_1953_0493cac) local storage library has stopped showing new recordings, while everything else functions normally.
- Local Storage Settings shows status "Good" with correct available capacity — the USB drive is detected and healthy.
- The library only shows entries up to around July 24, 2026 on my iPad (local WiFi) and August 15, 2026 on my iPhone (cellular or Wifi) when looking at it from Devices>BaseStation>Storage Settings, with nothing since. Also, no option to see local storage in the Feed tab.
- Live video feed works correctly, both on the same WiFi network and remotely over cellular.
- I do not have an Arlo cloud storage subscription, so only local storage.
- I have fully power-cycled the hub (unplugged 30+ seconds) — no change.
- Port forwarding and router configuration are unchanged and correctly set (WAN IP, ports verified) — but I guess this can be ruled out as it happens even on the local network.
Both iPhone and iPad are on Arlo app version 6.40.0 (34112) from August 4, 2026
Any help would be greatly appreciated
I have the same issues with my VMB4540r2. I guess Arlo is slowly weeding out their long time customers with no subscription. My Arlos are only wildlife monitors/motion detectors now, placed around my deck or patio watching for mice, raccoons and possum. Glad I have reliable Eufy cams with full features and ZERO monthly fees for security.
Hi all,
It sounds like there are two separate issues being reported in this thread. The symptom where the drop down is stuck Behrind the phones top notch/island is being addresses. The second, recordings missing from local feed is being looked in to.
The first report by @Concerned4U Has been identified and a fix is coming soon.
From my experience, they are now two separate issues. The most recent update (version 6.40.0) caused my Local feed option to not show up on the screen at all. The update before that (I believe 6.38.00?) was where the tabs to switch between feed options were up at the Dynamic Island of an IPhone where the time, signal strength, wifi strength, and battery are.
The symptom your experiencng has been identified and fixed, "Should" hopefully be released in the next app update for iOS. I'll continue to provide updates for you.
The iOS update corrected the issue and my local feed now shows
yes, fixed in app version 6.41.0
I can also confirm that after 6.41.0 the Feed shows the Local storage button... However, the second issue I reported is still unsolved. The local feed does not show any new videos either while connected to the same network as the base station over wifi or over cellular.
Local recordings can only be seen when your phone is connected to the same network as the hub. Cell connection won't work unless you set up a VPN connection to your router or set up port forwarding (the brief directions are in the Storage Settings in the app). Note that use of a VPN that connects to a server outside your network will also block access to the hub since your phone would be connected to a different network.
@jguerdat Yup, I had set up port forwarding in the router, and it had been working for a long time... but since the issue, now solved with 6.41.0 (the no local button in the feed), I can't view local videos neither in the same network nor from the outside (they're not even listed).
Try completely uninstalling and reinstalling the app. That has restored local storage access for me.
@StephenB Thanks for the suggestion. I tried it: completely deleted the app (including its data) and re-installed it. Didn't work 😞 (still the same issue)
Note: after re-installing I noticed that the app now reports that it's 6.42.0 (while the version I deleted was still 6.41.0) ...so, that means the new version doesn't solve it either.
Oh... wait... I've tried it again and after giving it a few seconds in the Local Feed it did populate the local videos list and I can view the videos recorded since I had formatted the USB drive. So, I guess 6.42.0 does fix the issue! Thanks for all the replies
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
