Newest Arlo app - Does it support more than 3 modes? If so, will it support 8 modes?
  • 3387 Views
  • 14 Likes
cambaync
We need to add my son to the Arlo app.  My husband and I are running the older Arlo app.  In another post by @jguerdat, they state the following:
Sharing with the new app requires some steps:
1) Everyone has the same version of the app.
2) Everyone has the same interface (the app supports the old and new interfaces). If needed, everyone should use Add Device to "add" either a Pro 5 camera or the security system - it doesn't matter which one nor does it matter that you actually don't have either one. This will cause the various accounts to all migrate to the new interface before doing anything else. When the migration is finished, cancel the installation. You may as well do this now since it will be forced at some point.
Note that you'll need to set up modes, etc. since your existing modes don't transfer over to the new interface. And, yes, there are only 3 modes available with no option (yet?) to add more.
My question is if the newest Arlo app supports more than 3 modes. We have 8 modes.  Will it support 8 modes?
@cambaync wrote:
To confirm, I would be limited to only THREE modes?!?!?  There would be no custom modes?
Correct.
Hopefully Arlo will put custom modes back into the new user interface.
No, it only supports 3.
Hopefully Arlo will change that at some point.
cambaync
These are my modes:
Armed - Motion detection on
Disarmed - Motion and audio detection off
Schedule - Manage based on schedule
Geofencing - Manage by your location
Front and Back - Custom mode
Front Back Shed Driveway - Custom mode
Front only - Custom mode
Front Back Shed - Custom mode
We were planning on upgrading all of our Arlo cameras to higher resolution Arlo cameras, but with this software mode limitation, we will be rethinking the system we choose.
Correct.
