Can’t find the Smart Notifications in the new, horrible, app. All my cameras and doorbell had them before.
Where are they?
Where are they?
Select the profile icon on the upper left, and then select your location in "location and plans". You should see "Smart Notifications" listed there.
Note I am using the iOS app, but it should be the same with Android.
Got it, thanks!
Also, this is where you can individually enable/disable notifications from a camera.
One place. Other options:
- Edit the rules in the three modes. That will let you remove all notifications for a camera while in that mode.
- Arm/disarm the camera. Disarming the camera disables both notifications and recordings.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
