HELP!!!
  • 6 Replies
  • 3109 Views
RedWolfie3
My base hub has gone offline. The Ethernet cable is working on my laptop fine. I have reset the hub. I have removed the device from my app and tried to re add it. Nothing is working! And I can’t contact Arlo support because there are no devices on my account so they won’t let me talk to them. There is no way to contact Arlo this is ridiculous!!
6 REPLIES 6
DannyBearAgain
Are you in NZ?
multiple NZ users are reporting similar issues.
BrookeN
Are you still seeing this same behavior @RedWolfie3
Sarah_NZ
I'm having the same issue...
This started Tuesday 5 Dec with both my cameras being offline for most of the day, when I checked my base station (after I got home from work) this was showing as being offline (amber light) I tried synching, unpluging power and ethernet and even using a difference LAN port on my modem with no success
I then tried to do a factory reset on the base station this also did not work and my Arlo app cannot locate any Arlo devices - the base station is showing as being online (blue light)
I have sent an email to the Arlo Support (Friday 8 Dec) with the above info - to date no response
Have tried again to re-attach the base station (over the weekend) and it still cannot locate it
RedWolfie3
Mine randomly just came back on. Luckily because Arlo are **bleep**! Literally no way to contact them. I did everything that you did as well, and my base station light randomly came on blue and I had to re-add all the devices now it’s working fine
RedWolfie3
at randomly just started working again, but I had to re-add all devices
Sarah_NZ
Thanks for your reply
This gives me some hope that mine will eventually let me re-add my devices. I will just keep trying
