  • 4 Replies
  • 3550 Views
Northern_billy
I have 4 arlo pro indoor cameras.  They are all plugged in the wall (not using battery) therefore always powered on.  Upon waking up from sleep I noticed one of my cameras had a solid blue light.  Even when I turned the camera off, the blue light remained.  I also unplugged it from wall and turned camera off from computer BUT blue remains on.  Your thoughts please?
Dannybear
The blue LED usually indicates the battery is fully charged. There is an option under the camera settings to turn it off.
https://kb.arlo.com/1200780/How-do-I-turn-my-Arlo-camera-s-Battery-Fully-Charged-LED-on-or-off
Dannybear
You can if wanted ( since you leave them all ac powered ) remove the battery and the blue led will not show.
Also, try pulling the battery and replace to see if it resets.
Northern_billy
Thank you very much for your time and response.  It's been resolved
Thanks again
Northern_billy
Thanks Dannybear - got it!
