  • 321 Views
Jacoba
I may be missing something, but after updating to latest Arlo Secure I can no longer "arm" the lights to trigger with motion detection, only turn them on or off.
Any body understand what has been changed
Jacoba
Found solution, have to add it into Standby settings.
Can't say I like the new approach - but will have to find ways of working with it.
ShayneS
Hi @Jacoba
Are you able to achieve this over the web? And which model device are you using? And Arlo App version?
Jacoba
ShayneS
@Jacoba
Thanks for the update, glad you found a solution.
Also, The team is also working on providing a similar custom mode experience. You can find more info on that here
