Library recordings gone
My library has disappeared. And no rexordings are happening.
did i miss something
my feed is no longer working. Ive had mine 7 years. Never happened before
did i miss somethingmy feed is no longer working. Ive had mine 7 years. Never happened before
What camera models and base model do you have?
Do you see "Library" in your app menu? Or do you see "Feed" and "Dashboard" instead?
I have the same problem since upgrading, no library available. I have the Pro 3 and all I can see is the Dashboard, Feed, Emergency, Devices and Routines. Everytime there is an upgrade things get worse.
Do you have a subscription?
Or are you using local storage?
I also have the same problem. I do not have a subscription. I lost Port Forwarding many months ago, after it was working fine - but could still see local recordings on my SD card as long as I was on the same network. After 'upgrading' to version 5.0.4 (why does it state version 4.0 on the update email!), I am now unable to see any recordings even if I am on the same network.
Are you looking in the right place?
The local recordings are not on the "Feed" page. You need to
- navigate to the devices page
- select the base station
- go into storage settings
to see the local recordings.
Yes, I am in the right place. I can see a list of recordings up to October 1st, some of which I can view as they have been previously downloaded. If I try to view those that are there but have not been downloaded , then I receive a message stating 'Videos stored on Arlo Base Station are not available. Please check your connection settings.'
There should also be several recordings since October 1st as I received many notifications of 'Activity' on my cameras over the past two seeks.
As far as the Port Forwarding issue is concerned, I have the correct port details in my Router but the Status is (and has been for many months) 'Not Available'. If I click on Status, I receive an 'Unable to connect to router' message.
Did you check that the port is open by browsing to https://canyouseeme.org/ ?
Have you tried clearing the app cache?
OK, since I have an iPhone I cleared down the cache by deleting and re-downloading the App. This has cleared down all of the old recordings (shouldn’t this be taken care of by formatting the SD card as I can see that old recordings will always remain viewable otherwise - until they are rolled off). So I’m left with not being able to view any new recordings (even if on the same network), which leaves me with a setup that only half works by allowing me to activate the cameras and view in real time. My understanding is that Arlo provides a full support service for customers with a subscription but not if (like me) you only purchase the equipment. Can you confirm?
Don't know why you think formatting the card will remove recordings you've already downloaded to your phone. But it doesn't.
So they are on the card, but not something you can see in the app when you are connected to your home wifi?
One path (definitely a PITA) is to remove the cameras and base from the account, and do a hardware reset of the base using a paperclip. Then add everything back, and set it up as new.
Regarding the SD formatting. Most of the old recordings had not been 'downloaded' to my iPhone - they merely showed as footprints. Since an SD format is supposed to erase all recordings, I simply expected it to clear everything. I subsequently noticed that you can clear cache via the Settings->Privacy option. It would make sense to me that if you format the SD card and do not use the Cloud, then everything should be cleared - simply a suggestion if this is a possibility.
Re the Port Forwarding issue, this has now been resolved. I think that it was a combination of doing a hard reset on the Base Station and setting up everything again from scratch (as you suggested); plugging my Base Station into the Gateway (instead of the Router) and figuring out how to setup the Ports to be forwarded on the Gateway.
Thanks for all your help.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
