  • 34 Replies
  • 16625 Views
  • 71 Likes
  • 16 In Conversation
Azurespire
Is there a way to revert this dumb update? I updated the app on my iPhone 13, and it singlehandedly RUINED my set up.  I had 3 cameras and a doorbell. once I updated to the "new" app not only did they all disappear they will not come back. I tried revoking access and inviting myself back in with no success. i have other devices on older versions of the app and they work just fine. this is ridiculous. is there a way to revert the app update and go to the older version of Arlo secure: home security app or am I just screwed from this device. I have re-sent invitation emails to my other devices and they have access but they do not pop up in the app.
34 REPLIES 34
It appears to be an issue with folks who are still using the old interface that uses Library to view recordings. Is that true for you, too?
londonmr66
Yes I am using Library to view recordings, this is how I have always done it and how I do it on my tablet.
There is no other way I see in the app to view the recordings.
You mention "old interface", what is this and why would it have changed after the app auto updated on Jan 7th?
Arlo began rolling out a new user interface back in 2023.  Folks using the original UI see "Library" in their app menu, folks using the new one instead see "Feed" and "Dashboard".
Old accounts have slowly been migrated to "Feed" - some intentionally by users, but I think also some silently migrated by Arlo.
londonmr66
Ok so what are my options, the current situation is unacceptable as I need to view the local recordings on my phone because I am not always at home and do not take my tablet with me when I am away
This appears to be a bug in the app.  If so, all you can do is wait for Arlo to fix it.
Getting a monthly subscription in the meantime is an option (though annoying).
I see app 5.4.2 has been released which may fix this. Keep checking to get the update (I just checked but I don't see it yet).
WandaK925
I feel your pain. I had no idea upgrading would wipe out all my existing settings.
Zalin
This can't be true. I am the only one with an account connected to my cameras. I have older cameras and used the old app and it worked fine. My app updated and now I can't even view live camera feeds. I can't figure out how to turn them on and off. They are all showing as offline but I keep getting notifications of movement. How can I revert back to the old app that actually worked?
Radses
I feel your pain buddy. I had this with all of my 9 cameras I ended up selling them all going to another company another brand But the is no way to revert back to the old app... that's arlo for you
Arloisaripoff
This is a very confusing app. The previous app worked fine for scheduling and now with the app upgrade, schedules don’t work properly, sometimes motion detectors work, sometimes not. Hey Arlo, why did you fix something that didn’t require fixing? And, I can’t call your support since I don’t have a subscription! Guess it’s time to contact Ring. You just lost a longtime customer.
