  • 9 Replies
  • 4526 Views
FredrikHarfjeld
My outdoor Arlo Secure essential kamera suddenly says «Inactive». I have tried to turn it off/on. The battery is full, The Internett is ok, and The picture is ok, but it dies not record. I’ve deleted it and tried to servitutt again, but it is still inactive
9 REPLIES 9
Is it in a subscription plan?
FredrikHarfjeld
Ja, via verisure
Ja, via verisure
Ok.  Can you livestream the camera?
FredrikHarfjeld
Ja
Ja
Can you make a manual recording while livestreaming?
Have you checked the mode you are using, and made sure there is a rule for the camera in the mode?
FredrikHarfjeld
Ja, man kan gjøre manuelt opptak
modus? Jeg forstår ikke hva du mener?
If you have a subscription for the camera, you can make a manual recording while livestreaming.
If you touch the video image while livestreaming, you'll see various icons appear.  At the bottom center, there is a "target".  Touch that and recording will start.
Martti59
Hei.
Minulla sama vika.
En saa kameroista yhteyttä puhelimeen.
BrookeN
Which camera are you trying to connect?
