Could you improve your user interface so that you could specify which cameras will send an alarm and which not. There typically are some cameras which also records movement from for example nearby streets or the wind is just moving the bushes and so on. So you do not want an alarm everytime a car passes by or it is windy. But you do want the alarm if someone is at your front door or moving inside your house for example. So you should be able to individually specify which cameras send you the movement alarms and which not. Thanks.
Those settings are in your modes and rules. Make sure only the desired cameras have notifications enabled.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
