How does the Keypad Sensor Hub connect to the wall?
  • 6 Replies
  • 2844 Views
josephfonseca
What happens to the 3 cameras, the Smarthub, RBR960, nighthawk and Orbi app?
6 REPLIES 6
Unfortunately there is no wall mount.
What do you mean???
The cameras and smarthub are still part of your Arlo system, so nothing changes there.
The Orbi/Nighthawk stuff has nothing to do with Arlo.  You do of course need internet service for Arlo's solution to work.  But that doesn't have to be Netgear kit.
josephfonseca
How does the Keypad Sensor Hub attach to the wall?
Is it the same as plug in outlet?
It doesn't.
josephfonseca
Does the wired unit plug into a wall outlet?
Yes.  It plugs into a USB power adapter.
josephfonseca
Thanks...
