  • 48 Replies
  • 5560 Views
  • 4 Likes
  • 6 In Conversation
Tomwebb81
Hey All,
About to buy 2 replacement cameras but this will mean I need to upgrade the app to the new version. I’m currently using geo-fencing based on the below setup.
Can anyone confirm if Arlo have fixed geo-fencing in the new app and the below setup is achievable? Tia
2 iphones - one master login and then one logs in using a separate login with granted access
2 cameras and 1 video door bell
currently I have in the old app it set so that geo-fencing is the default and if both phones leave the house it sets to away mode and arms and then once one of the phones returns it changes to home mode which is set to schedule. The schedule is from 8pm - 6am to be armed and 6.01am-7.59pm to be disarmed.
48 REPLIES 48
alex_loo
Virtuoso
Virtuoso
My quick answer is "NO, it is not working all the time"
Setting up above in new app is simple IF ARLO has fixed the geofencing bug I mentioned above.  That is -- yes the design of new app can achieve your use case easily, but no the new app is still buggy enough to make you unhappy.
Alex
Tomwebb81
Thanks Alex, curious on the other thread it was very active and then suddenly stopped around Aug. Is that because everyone has exhausted and is awaiting a fix from Arlo?
If so does anyone have any official comms with Arlo over resolution?
I went through all this years ago with the 1st app and geo fencing when it 1st came out and they recked if with an update for months. 😞
WimD
Still not working! This started for me this past summer, and still does not work with the new app and Arlo Secure subscription plan. So frustrating that Arlo does not address this issue.
alex_loo
Virtuoso
Virtuoso
dunno how to answer the question 😅
So far I don't even see ARLO socializing their issue lists to be fixed, at least from a user expectation management perspective.  So for geofencing, yes I do see issues there but no I haven't seen/heard any acknowledgement of them by ARLO --- not to mention about any plan of fixing.
And the more annoying thing is --- I can tell they are reading this community here!  They are just doing nothing to our yelling.
Alex
Tomwebb81
Thanks Alex,
Looks like I will stick with the old gen cameras for now. ☹️
poor show Arlo.
The first steps are to
  • Configure both Arm Home and Arm Away to arm all cameras
  • Configure Standby to Disarm both cameras
All of these modes should already be set up this way, since they are the defaults.
Then configure two schedule automations
  • one to change the mode to "Standby" at 6:00 am
  • one to change the mode to "Arm Home" at 8:00 pm
Finally two geofencing automations
  • one to change the mode to "Arm Away" when everyone leaves
  • one to change the mode to "Arm Home" when someone returns
With "Library", the system would automatically pick up the scheduled mode when you return.  Unfortunately, Arlo missed that in the new design - you need to select one mode when you return.  So if you return home during the day, then you would manually need to switch to "Standby" to disarm the cameras.  If you forget, the cameras will still disarm at 6 am the following day.
The geofencing triggers aren't 100% reliable.  Mine are working pretty reliably, but I have seen the system miss a couple of triggers.  FWIW, some people reported this with "Library" also, so I'm not sure this aspect is actually worse.
HanSoloMumma
My geo fencing isn't working on the new app, no matter how many times I do a test and it confirms it's all good. It just will not turn on when I leave the house. It worked 90% of the time in the old app, 0% of the time in the new one.  May as well just leave my front door open for the good the cameras are doing.
As a test, try enabling your "leave" and "arrive" automations in all modes, and see if they trigger then.
HanSoloMumma
@StephenB I have, literally every night I do this, hoping that next time I leave it will work, yet the next time I leave the house, it still doesn't activate.
Can you post screen shots of your automations?
HanSoloMumma
@StephenB
@StephenB
Leave needs to be enabled in Standby (since that is the mode you switch to when you arrive).
Generally Arrive is only enabled in Arm Away.
Do you every use Arm Home?
HanSoloMumma
@StephenB Thank you! I've navigated to Standby and enable Home (leave), so hoping that function now works. What an extra level of complexity that wasn't an obvious change to this user at the very least. I have previously used Arm home, however do not at present. Is there anything I need to know for setting that up correctly that isn't as obvious as it could be?
If you also want to use scheduling, then I suggest setting up Arm Home and Arm Away to be the same (using the same camera rules).  Then have the schedule switch between Arm Home and Standby.  That setup ensures that "Arm Away" leaves the cameras armed 24x7 until you return.
But if you don't care about scheduling, then you can leave things as they are.
HanSoloMumma
@StephenB  After enabling Leave via the Standby mode as suggested, I was hoping that would trigger the camera to arm upon leaving home (Standby mode). Sadly this wasn't the case.  Is this setup right? My previous 2 screenshots remain as is.
If you put the system in Arm Home or Standby, and then use the "test automation" in Leave, do you see the mode change to Arm Away show up in the "Feed"?
HanSoloMumma
I've finally got Arm Away to work! It always worked when using Test Automation, but never "IRL". I've clearly got the Standby when arrive home screwed up though, because when it's 'on', it doesn't work, and arm away doesn't either, but turn off Standy when arrive home, and it then works.  I guess I'll work it one day, but for now at least it's turning on when I leave!
Can you post your arrive automation?
HanSoloMumma
@StephenB never mind I've finally worked it out 😆 appreciate all your guidance. It really should not be so difficult - great concept, **bleep**e execution.
alex_loo
Virtuoso
Virtuoso
hi @HanSoloMumma , how many devices do you have in your geofencing routines?
Alex
HanSoloMumma
@alex_loo thankfully only 2! Any more and I think I'd have given up and binned them!
alex_loo
Virtuoso
Virtuoso
Hi @HanSoloMumma ,
Nice, may I know:
  • How long and roughly how many times has this good geofencing been working?
  • Have you tried first device leaving (no trigger) and then 2nd device leaving (all away trigger)?
  • How you tried, with both away, having one device returning (triggering arrive routine)?
Hope you don't mind the many questions.  I have been looking for a working case I can copy from! Thanks .
Alex
HanSoloMumma
@alex_loo scrap that - I retract my previous statement... it had me fooled - notifications were delayed and sending at odd times so no, I'm back to getting it to turn on only when I leave, but not off when I arrive. It literally makes zero sense. A colleague who has many years of experience with IT systems and also security systems has had a look today, and his logic hasn't even worked, so whoever the heck designed this upgrade needs to talk to their UX team.
alex_loo
Virtuoso
Virtuoso
hi @HanSoloMumma , thanks for the update.  Curious what the version number with your ARLO app is?  (top left avatar >> About)
Alex
(still keeping my at 5.4.2_28786 here)
