Hi there,
I'm being double billed with two transactions pending. Can this please be checked out?
Also, is this the only channel to get in contact with you?
Please reach out to support. You get to that by going in the support area of the app (not my.arlo.com), and selecting a camera in a subscription plan. Scroll down to the contact section, and you will see an option for phone support. It is available between 6 am and 6 pm US pacific time.
Can you please just give us the number? There are no numbers posted anywhere in the app. We also just discovered that we have been being double-billed since last MARCH! We need to get this fixed and no one seems to be able to help. The "chat" function is completely useless. I need to speak with someone about this billing issue!
Arlo doesn't publish them (note I don't work for them).
Don't google for one, that will almost certainly lead you to a scam support site.
I was afraid of that. I guess the only recourse is to cancel our subscription.
Is there a reason you can't use the phone support feature in the app???
I cannot find any "Phone Support" option in the app.
If you see "Library" as a menu option in your app, then use these instructions:
https://kb.arlo.com/000062461/What-is-the-Support-Center-in-the-Arlo-App
If you see "Dashboard" and "Feed" instead, then use these instructions:
With "feed" there is a pop-up that shows up when you go into the support center that you need to dismiss (touching the "x" in the upper right).
You also need to scroll down to see the "contacts" section.
As the two articles say, phone support is available from 6 am to 6 pm US pacific time.
I've opened a support ticket detailing the concerns you've posted here. An agent will reach out to you with a status update as soon as possible.
Close ticket.
669-677-8950 I have been getting double billed since last January and theu didn't want to refund me. They only offered $9.99 refund from c the already $140 plus thr $155 I already paid please be careful and check your plans
Bilking number is 669-677-8950 I have been getting double billed since last January and theu didn't want to refund me. They only offered $9.99 refund from c the already $140 plus thr $155 I already paid please be careful and check your plans
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
