Hi, if I have a Secure subscription (as opposed to a Secure Plus subscription), will the 'live feed/streaming' be displaying onscreen in 4k (since the cameras are 4k Ultra2 cameras) but the recordings stored as part of the subscription be in 2k?
Or: will the 'Secure' subscription mean that my Ultra2 4k cameras now only ever operate in 2k, with 2k live streaming, and with 2k recordings of motions etc? (i.e. downgrading the operation of the cameras entirely)
Obviously, what I would have thought is reasonable, is that under a 'Secure' subscription, I should remain with 4k live streaming, but with 2k recordings (since Secure only records in 2k as per the deal). But if I wanted 4k recordings, then I'd need to change to Secure Plus.
My subscription is in Spain, €9.99/mth Secure subscription.
A definitive answer on this would be great, thx,
Both recordings and livestreaming will be 2K.
Thanks for the info.
Do you think that's fair?
@AntoniXXX wrote:Do you think that's fair?
Personally I have a Secure Plus subscription. Though I also don't use 4K livestreaming, as I prefer the option to make manual recordings (which is disabled if you use 2K or 4K livestreaming). So I'd rather have 4K recordings than 4K livestreams. Though obviously different folks will have different opinions on this.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
