Morfaren min sliter med at når de går forbi arlo dorbell wireless så lager chime 2 en lyd uten at de har trykket på dørklokken hva skal jeg gjøre
Check the rule for the doorbell in the mode you are using, and make sure it isn't set to sound the chime when motion is detected.
Thanks im going to try it out
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
