Hello -- I just purchased a new arlo4 pro camera and added it to my arlo hub. that was easy and it connected without issue. however it is now listed as being in a trial single camera plan, apart from my current arlo smart premier plan which supports (10) cameras, and there is no way provided to drag it out of the trial plan into an empty slot in my current cluster cameras. I've chatted with support with no satisfaction as i was told to just wait the (3) months and the trial will end. Is that my only recourse? Sounds strange to me. Let me know what you think out there, and thanks for reading.
Waiting for the trial to expire is the easiest way.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
