Both my Arlo Pro 2 & Arlo Essential XL Outdoor (Gen 1) are showing up in the Arlo Secure app as unavailable.
One was plugged into power, and the other had solar.
I took both cameras down and plugged them into different power supplies, to no avail.
Did the life of these two cameras just end?
Both models should still work.
Are both connected through your base?
Did you try removing/reinserting the battery on the Pro 2?
Also, did you try power-cycling the base?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
