							Camera strenght with different routers
Does it make a difference in what type of router is being used on the network. In the main office which manages 15 ARLO cameras is an older router. If I was to upgrade to a more powerful router (wifi 6) would this increase the reliability of my ARLO connections? Or is that manage by the ARLO Base station?
If you use a base station, then the cameras connect to a closed wifi network that is created by the base. That network cannot be extended, and all Arlo bases have about the same reach.
If some cameras aren't getting enough signal, then you can add another base that you can place closer to those cameras. Then you'll need to remove those cameras from your account and add them back (to the new base).
We have two sets of cameras. One around the clubhouse. The others are over400 feet away. ( we do have a network extender). But if I was to add another lan base, I would have to connect to our router which is 500 away!
just thinking
That wouldn't extend the Arlo network unless it is a simple repeater. But of course you can connect a base to the extender.
Do you have any way to scan for wifi networks and show the signal strength? There are some free apps that will do this for Android phones and PCs. Unfortunately not iPhones (Apple doesn't allow it).
There are some outdoor wifi systems that can cover that distance - either getting you an ethernet connection at the base location, or letting you use a wifi-connected camera (with no base).
Ethernet cables can't run that far (they are spec'd for up to 100 meters). But you can run ethernet over coax with suitable transceivers, and that can reach that far.
						Activity Zones1
						Applications mobile et en ligne2
						Arlo 4.1 App release notes1
						Arlo app1
						Arlo Mobile App351
						arlo not working2
						Arlo Pro 51
						Arlo Pro 5S 2K1
						Arlo Secure1,202
						Arlo Secure 4.02
						Arlo Smart115
						Automation1
						Before You Buy86
						cameras1
						custom modes2
						Features145
						Friend1
						Geofencing1
						Grant Access1
						IFTTT1
						Installation59
						Modes and Rules1
						my.arlo.com1
						notifications2
						Pro 5s1
						Security System App1
						Smart Subscription1
						Temporary disable1
						Troubleshooting379
						Vacation override1
