I am using the Arlo Secure App and it looks like I got a recent update on my Android smartphone and now my camera notifications are showing up very sparsely. They were working fine before but now, not so much. When I go to settings on the app and about, it shows ver 4.4.1_28536, released 5/25/23. My wife has an Android also and uses the same app and hers is working fine. The release date on her app shows April so my feeling is that something in this new release messed up my notifications. Thoughts?
tkdog1,
When you say sparsely, are you indicating you are receiving notifications but not all expected notifications? Is there any pattern to the notifications that you are receiving (from a specific camera, during a specific time, etc.)?
I receive some notifications but not all. It seems to go in spurts. I dont get some in the morning then I get some in the afternoon or the other way around. Unfortunately I have not come up with a pattern.
I have experienced exactly this same problem on my android smartphone. I contacted tech support line but so far no solution. Apparently this issue has been escalated to engineering team but I have to wait. This is why I downloaded previous app version 4.3.5_28531 from APKmirror website and so far I have no issues. It would be nice if Arlo treated this issue seriously as notifications are quite crucial features of their product.
Thanks for the info. I may try that. It has been very frustrating.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
