I cannot purchase a subscription. This app and website have endless glitches. I can log in on the app. I can log in on the website. If I click “join now” or any link related to purchasing a plan it either does nothing or prompts me to login AGAIN. Then I receive an error message on the second login. I have two tickets open. The first said this was a known issue and they did nothing. The second ticket said it doesn’t work on a phone and I have to use a PC. Used a PC. Same exact result. Now they won’t respond to either ticket. My cameras are completely useless now. I can’t even return them because I’ve had them until the trial period ended. Complete waste of money. I will end up throwing the camera in the trash.
If you’re using a iOS device the app will not allow you to access their web portal in-house links.
You need to access the arlo web site on a browser not the arlo portal site.
https://www.arlo.com/en-au/arlosecure.html
What country are you in?
USA
@Wadewiz wrote:
USA
Ok.
Are you saying that when you log in on the PC, and then click Settings followed by Subscription that you are asked to log in again?
If not, where along the path are you getting the second login request?
Some users have had issues with autocomplete on their PCs, so if you are getting to the point where you enter your credit card information, you might want to try entering it all manually.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
