Is it possible to create an automation where my camera would start recordings with motions and/or activate a spotlight only in the evening hours? We have pets and are out back quite a bit, so we don’t need the camera recording for every motion throughout the day, but I would like the recordings, and the spotlight to turn on at night.
Which user interface (UI) are you using - the old one that uses Library to view videos or the new one with Feed?
Generally, you need modes with appropriate cameras listed in each one - any camera without a rule is disarmed. The spotlight is a setting in the camera rules as well as the camera settings. Edit them as desired. Then use the schedule to automatically switch between modes at appropriate times.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
https://kb.arlo.com/4900/How-can-I-set-a-schedule-for-my-camera-in-my-Arlo-account
Note these links are for the old UI but there's a link near the top in each to go to the new UI instructions.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
