Arlo Security System Automation Bypass
  • 2 Replies
  • 3490 Views
TScotty
In Arlo Secure I set up two Automations to switch between the "Arm Away" and "Arm Home" modes based on the time of day. Is it possible to override these Automations for when I'm on vacation? For example, I would like to have Arm Away set for the entire period when I'm gone, i.e., skip the daily scheduled switch to Arm Home.
Not that I know of. Maybe the quickest/easiest way would be to simply edit the Arm Home to use the same mode as Arm Away. Of course, you'd have to remember to change it again on return.
TScotty
Thanks, @jguerdat. It would sure be nice to have a toggle to enable/disable schedules like many programmable home thermostats have. I hope to see something like that in a future upgrade.
