  • 12 Replies
  • 1832 Views
Vinny_V
My Arlo feed has all of a sudden stopped showing anything since last week. In the date picker, it only shows last Thursday.
I've checked my subscription status and it's fine. I've logged out and in. I've restarted the app and nothing seems to work
Vinny_V
I reset the wifi connection on all of them and it appeared to fix the issue.  Pretty much a manual reset and reconnection fixed it. Disappointed that it needed it but at least it's working now.
12 REPLIES 12
ShayneS
Hi @Vinny_V
Are you still experiencing this symptom with the feeds?
Vinny_V
Yes. It hasn't updated since Sept 12
Can you make a manual recording while livestreaming?
If you can, are you seeing it in the feed?
Vinny_V
Still doesn't appear in the feed. Also, in the feed view, it would be great if the icons were not blue as it makes them incredibly difficult to see.
Vinny_V
 this is my calendar view
Vinny_V
It showed up in my single feed view for 1 of the cameras
Did you double-check the feed settings?  The filter settings are persistent, and it is easy to forget to undo them.
Another thing to check is the rules for the mode(s) you are using, just to make sure the cameras are armed.
Vinny_V
Yeah, I've redone all the feed settings and reset all the modes and automation settings 
Vinny_V
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Vinny_V
ShayneS
@Vinny_V
Thank you for the update.
