  • 2851 Views
kapinator
When I try to access my PIN setting interface the app just spins with the loading screen.   I log in, select Settings, then my location, then Pins, and it just spins on the loading screen.  Happens in the app and on the web interface.  I've tried unplugging my Keypad Access terminal but it didn't help.
kapinator
Something must have been fixed on your end, it started working again a few hours later.
ShayneS
Hi @kapinator
Which version of the app are you using?
kapinator
ShayneS
Thanks for the update.
