App does NOT work
I have nothing but problems with the app since the last update. I get notifications but they don’t go to feed.
What cameras do you have?
Are they connected to a hub?
Do you have a subscription?
@cconsemiu wrote:
I ha e the essentials spotlight camera and yes all cameras have a subscription. I am not connected to a hub.
Thx
Are you using the primary account, or are you perhaps using a "friend" account?
First I suggest making a manual recording while livestreaming one of the cameras. That would confirm that there is no issue with the subscription status.
Second I suggest checking the mode you are using (Armed Home, Armed Away, Standby). If it is Standby, then switch to Armed Home or Armed Away. Also check the rules in mode you are using - making sure it includes the rule for each camera, and also double-checking that the rules are set to notify and record.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
