  • 31 Replies
  • 3430 Views
  • 2 Likes
  • 12 In Conversation
Adonaldson0014
Since the update the app crashes when opened. If I delete and reinstall it works once then crashes. Cannot access anything or make any changes.
Best answers
  • BrookeN
    Please update the app to the newest software version, it will be 6.11.1. Once updated you should no longer be seeing the behavior of the app crashing. If you do still  experience the same behavior, please reach out to me and let me know.
    Thank you
  • BrookeN
    We are currently investigating the behavior you are seeing and are currently working on the fix. I will update the community as soon as possible.
31 REPLIES 31
ElTripper
Good Morning... Hope someone can help, I Tried using the chat on Arlo website but it is like trying to talk to a wall, you just never get a real answer
Ok so my problem is that the Arlo app stopped working on my iPhone 17 pro max, it used to work on the 16 pro max but now it just gives me the "unknown error" message, but I can watch and login using the website on my Macbook just fine, I am running iOS 26.2, any help with this issue will be much much  appreciated, Thank you
Cameras I use are the VMC3030
BrookeN
Can you try uninstalling the app and then reinstalling it and see if you are able to login?
ElTripper
Sorry, I forgot to add that I have done that, I even tried on my iPad just now and nothing, it gives me the same message, do I need to reset all 3 of my cameras?? and make a new account?? Thank you
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
ElTripper
Will do, Thank you so much
BrookeN
Thank you for providing that information. I have reached out to support, they will be contacting you as soon as possible.
ElTripper
Got it, Thank you
Fscam2005
Hello Community,
I have a iPhone 17 pro running iOS 26.2. The Arlo app immediately crashes crashes when trying to load. I have deleted websites history, deleted the app, turned iCloud back up off, poeeed iPhone off and back on again and re installed the app. Still nothing. Anyone know of this issue, and if there is a fix? Or are we waiting on Arlo to push a update through Apple to rid the bug?
many Thanks
Taylorcrobi
My app suddenly stopped opening. What should I do?
BrookeN
Are you on iOS or Android?
BrookeN
What device are you using currently iOS or Android?
Adonaldson0014
I use IOS 16 Pro. I am running the latest IOS Version 26.2
BrookeN
When did this start happening? Was it after an update?
Adonaldson0014
It started after the update. Yesterday is when it began to really crash every time I tried to open the app. I can delete it, add it back, will work one time and then crash again!
BrookeN
grasprah
I am also having this issue since the update. The app crashes immediately upon trying to open it, but I know my doorbell is working because I'm still getting notifications from the Arlo app somehow, and I can view the live feed from my Alexa app. I have an iPhone 16 Pro on 26.2. I have uninstalled and reinstalled multiple times, as well as rebooting my phone itself.
Dane875
Ever since last night the Arlo Sercure App will not open on my iPhone 17.  I used it yesterday morning without issue , but last night  when I click it the blue house comes up for 2 seconds then disappears, never opens the app. If I delete the app it will open after reinstall the first time but will not reopen after that. I have tried offloading the data reinstalling , turning off WiFi and cell and forcing login and logging I from a computer and then trying the app. They all do not work. I know Arlo pushed an update out 4 days ago but the iPhone is up to date. Was working flawlessly before last night.
Malia_Putnam
My app is doing the same exact thing as well. Let me know when it gets fixed please. Thank you!
Thesch
Same here
BrookeN
Thank you
Bill6625
Exactly the same time frame and same problem
BrookeN
@Bill6625 you are still seeing the app crash upon opening? Can you please send me a video of what you are seeing?
Blues22
Well, it looks like Getting Status has finally been fixed, thank you, and if you can make the lag time better for when someone walks in front of the camera, the time I get notified, the person is long gone. And I have one in my backyard just to keep the deer away from my vegetables. The time I get notified, damage is done. It never used to be that way; it was just a few seconds, but now it's much longer. This started more than 6 months ago; if that was fixed, it would be golden.  My friend has a different brand with almost no lag time.
tonys81
My app is doing the same thing on iPhone 17 pro max.
Only opens to Home, no login option.
No error msg.
