arlo will not sync after losing connection
  • 6048 Views
rhoneycutt21
camera lost connection-  went to resync - unplugged it,  reset it and started through the set up process at least 5 times-  after reading the IR code  it tries to sync them beeps and goes back to amber flashing light    only had this camera 5 weeks
rhoneycutt21,
Did you first remove the camera from your account before attempting to resync?
Log in to your Arlo account and navigate to Settings > My Devices > select the camera > Remove device.
After the device has been removed, attempt the sync process again.
rhoneycutt21
i fixed it-     and i got an email from netgear saying if i did not reply they would consider the case close  yet the email is a no reply  so how are you suppose to reply?
rhoneycutt21,
I am glad to hear you were able to resolve the issue. If you provide me your case number in a private message I will take a look at the case.
